310 ELEC. CHARGING PROB.
C.D. ZOOK
12-25-2002 09:25:52
Hello & Merry Christmas and a happy New Year to all. Help Request!! Running a 8 volt battery, Took generator to a reputable repair shop for rebuild and had it double checked, and confirmed gen. is working properly. Ran new wires from gen. to a brand new volt. regulator, followed elec. checks per instructions w/new regulator, but when I polarize the reg. I do not get a spark when jumping batt. to arm. posts. Have new heavy duty battery cables, with contact areas cleaned & elec. grease applied. Amp gage shows a proper amount of discharge when load is applied to system, but when tractor is running at 1/2 throttle or more, still shows zero to very slight discharge on amp. gage. Any suggestions would be appreciated. Thank You in advance. C.D. Zook
chuszy
12-27-2002 06:06:28
 Re: 310 ELEC. CHARGING PROB. in reply to C.D. ZOOK, 12-25-2002 09:25:52
C D I also had a 8 volt battery in my 1957 310 gas (6 volt system). I was told by a local tractor dealer to just use a good 6 volt battery. I installed one and have no problems since. It starts right up even at 0 degrees F.
case poor in pa
12-28-2002 16:31:19
 Re: Re: 310 ELEC. CHARGING PROB. in reply to chuszy, 12-27-2002 06:06:28
my sources said aint no way you can tweek a 6 volt into a 8 volt regulater..im disclaiming this statement as my names bob not ben. and electric isnt my forte.( that word means i dont know much about it) also ben as in franklin...
C.D. Zook
12-26-2002 03:55:23
Thank you for the responses, but I am still puzzled about no spark present, when I attempt to polarize the new regulator. I am aware that the regulator & generator may have to be tweaked by the elec. repair shop, to compensate for the 6 volt verses the 8 volt battery. I will call them to see about having this done, if possible to set up the voltage, or not. Thanks, C.D.Z.
Irv Slagter
12-25-2002 15:36:41
Casepoor is about right except that if I remember right, I think that you can tweek the original 6v. regulator till it puts out 8 volts. Course maybe my memory ain't too swell either.;^) My dad did an M farmall that way back in the sixty's and it worked great. Somebody correct me, but did they even make an 8v. regulator?
Irv
Haycreek
12-25-2002 14:47:05
I too had once put an 8 volt battery in my 311,,, didnt work, it was a 6 volt system then,, the generator has to put out 8volts,,, it only put out 6.2 volts, converted to 12 volts after that, GL.
case poor in pa
12-25-2002 09:59:33
if thats a 300 case we have a 1960 its a 12 volt system anyway they told me at hess's equipment in canton pa once that if you use a 8 volt battery you gots to have a 8 volt regulater 6 wont work right.. mite want to check into that .. im disclaiming all this what i just said as hear say except our 300 is 12 volt mery christmas im gone
Richard in W V.
12-26-2002 15:35:05
 Re: Re: 310 ELEC. CHARGING PROB. in reply to case poor in pa, 12-25-2002 09:59:33
C.D unless you are just wanting to leave the orginial charing system on the machine i would change it over to 12 voilts.GM alternator with built in regulator you will have to make a new bracket to mount the alternator.and if it is gas you will have to have a resester in line to cut power to 6 volts at the points.
