Case 580C
Greg Bowden
12-26-2002 11:36:51
I have two six volt batteries in series on my 1978 Case 580 C. I have been having problems with them holding a charge. Can I install one twelve volt battery instead of the two six volt, would it work ?
scottAR
12-30-2002 18:57:04
 Re: Case 580C in reply to Greg Bowden, 12-26-2002 11:36:51
I would try one twelve volt battery and if that was not satisfactory then get another twelve hooked up parallel. Won't cost much more and then if you get a bad connection on one it will go ahead and start at least in good weather. Then you have an extra battery for something else if you need it. I've changed over Cases, IHs, and JDs and am much happier. That's just my opinion and it's like other things, everybody's got one.
ACPhil
12-27-2002 13:26:21
I agree, that when one battery is weak it will pull the other battery down. My brother was one who would charge and charge old batteries and think they would come back to like. I guess he didn't like to spend money for new batteries. I get two new batteries. I'd also pay attention the all the battery cables. With all that voltage going through them it must weaken the wire inside tha cables. Especially if you have had to use jumpers to start it many times. I'd go to the welding supply, get some welding cable, get solder on ends, and make new cables. Sometime this was time consuming, but it's just a piece of the puzzle you won't have to worry about. Merry Christmas and Happy New Year, Phil
case poor in pa
12-28-2002 16:27:01
 Re: Re: Case 580C in reply to ACPhil, 12-27-2002 13:26:21
your brother and my brother must be brothers .. screw around with junk instaed of spending a little loot. it aint worth all the work doing it halfassedly... quicker and cheaper to do it right
Max
12-26-2002 21:20:48
Don't really remember any 580C's having a single 12 volt battery, only the 580D had one and was it ever a bear to get to. The 1978's 580C's had the Delco starter and if yours still has the Delco, you will want the extra cranking power of the 2 six volts when it get below 50 degrees F outside. If your 580C has the Nympho starter, then you could get away with a good group 30 battery but I don't think it will fit in the battery box. A group 27 may fit but those batteries just don't seem to have the lasting power of the group 30 when cranking during a cold morning. Hope this helps.
case poor in pa
12-26-2002 18:00:31
if you got 1 weak one it will ruin the other after awhile. then if you replace one if the other isnt as hot as the new one after awhile 1 of them goes KAPUT so really you should put 2 new ones in, but im sure somebody wont agree to that . so im putting in a diclaimer. but i have been around diesels for the last 27 years but it doesnt mean im right
DaleIN
12-26-2002 12:52:13
Hi Greg,
Some 580Cs came from the factory with a single 12V (30H) battery. They have a different battery box, but I'd guess it would work. You'll be losing some cranking power by switching to a single 12V...But, I wonder if you'll be gaining anything? It seems if you have a draw or other charging problem, won't you still have a problem with the single 12V? Or are you just wanting a 12V because its cheaper than 2 6vs?
