6 volt coil for 46 VAC
Roger Rachowq
12-26-2002 20:13:47
Where can one buy a 6 volt coil for a 46 VAC or can you use any 6 volt coil? The 46 VAC has a 12 volt battery and the generator is not connected, I suppose it has a 12 volt coil and I want to put it back in the original condition. Thanks
mj
12-27-2002 23:34:00
 Re: 6 volt coil for 46 VAC in reply to Roger Rachowq, 12-26-2002 20:13:47
Does it have a resistor in the wire from the ignition to the coil? If it does then it is a 6v coil set up to run on the 12v battery. To use it with a 6v system just remove the resistor. If the coil is actually marked 12v and "use with external resistor" you can use the coil on 6v. If it says 12v "no resistor required" (it has one built in) in which case you need a 6v coil. I convert my VAs to 12v using the original coil with a 12v ballast resistor from breaker-point era Chevys and Dodges. If you need a used 'gennie' I'll trade you one of mine for a 12v "no resistor required" coil.
case poor in pa
12-26-2002 21:28:16
ive gotten them at napa and central tractor.. tractor suppy now .. changed the name but its still the same place
