Case 2670
Oliver459
12-27-2002 17:57:55
I have a Case 2670 and would like to set the hydraulic pressure up on the remotes.
How do I do this?
Thanks in advance.
Lloydl
12-28-2002 20:09:54
 Re: Case 2670 in reply to Oliver459, 12-27-2002 17:57:55
There's a plug on the bottom of the remote valve that takes a 1 1/4 wrench. that's the releif valve , it is adjusted by shims. A .030 shim raises psi about 300 to 400psi. Be sure to check the rest of the releif valve blown ORs will cause low presure.
