CASE 300 Tach,and speedo
Joe
12-30-2002 04:50:45
Hello, i am looking for a working tach and speedo for a case 300. THe one I have just stoped working and I figure a gear stripped out. Please let me know if you have one and what it's worth. Thanks Joe, Also are they intechangeable with any other case models? Thanks again.
John Saeli
01-09-2003 16:25:06
 Re: CASE 300 Tach,and speedo in reply to Joe, 12-30-2002 04:50:45
Joe; If you haven't found parts already, I have NOS parts for your dash, including the tach and speed-ometer. They are exact replacements for your S-
W dash.
case poor in pa
12-30-2002 17:30:26
you should tell if its a seperate unit or all under 1 glass.. our 300 its all under 1 glass 1960 b.... will make it easier on evrybody im disclaiming what i said as it mite not make it easier ...DON L email manifold@smig.net he can help ya maybe...
Joe
12-31-2002 09:16:32
 Re: Re: CASE 300 Tach,and speedo in reply to case poor in pa, 12-30-2002 17:30:26
Yes, It is under one glass like you said. What is one worth? Interchangable with any other modelss?
Joe (Wa)
01-01-2003 11:05:14
 Re: Re: Re: CASE 300 Tach,and speedo in reply to Joe, 12-31-2002 09:16:32
Hey Joe, All the 300's I've seen have separate speedometer and tach/hour counter gauges. The speedometer gauge movement is electrical (no gears in there) driven by a speedometer cable from the transmission. The tach gauge movement is also electrical with some gearing that turns the hour counter. This gauge is driven by a speedometer type cable attached to the tachometer drive gear in the torque tube. If you have this setup, the most likely problem is that the drive cable core is twisted off. You can buy cores or have one made up @ a speedometer shop. If the problem is in the gauge movement, it may be stuck or have worn bearings. I repaired mine with movement parts from a junk 530 diesel panel. The 530 is NOT a drop in replacement, it is designed to turn in the opposite direction for one thing, but the major parts of the movements are the same. You may not want to try this unless you have instrument repair experience. I think your best option is a salvage yard. E:mail if you think I may be of some help. Good luck, Joe
