430 landscaper special
Shawn Scott
01-01-2003 16:04:28
We have a Case 430 that I would like to find more info about. It is almost impossible to parts for it. We have found some parts for it listed as being a landscaper special. I was wanting to know if anybody could tell me if it is a rare or oddball tractor. Here are the serial numbers
tractor: Model 430G # 8192655
loader: Model 22 # 4069401
It is a gas with a nonadjustable front end,4-speed with hi/lo transmission. It also has a shuttle shift. It does not have a PTO or any hydrualic outlets. Thanks
Dennis/Ohio
01-01-2003 22:47:55
 Re: 430 landscaper special in reply to Shawn Scott, 01-01-2003 16:04:28
Hi, Seems anything is possible with a 30 series. I try to file any info I get to help the next guy with a 30 Series. You have a good start since you have both of the model and serial numbers. Your 430G is near identical to Zach's 440H. Both are Utility Tractors or Standard Tractors with gas engine. I recommend a parts manual for Utility Tractor and a manual for 22 loader. Having your part numbers seems to help. The Dealer can cross part numbers easier than look them up. The 22 loader was built exclusively for the 430 yet zach has a 21 loader. Call Rich Tworek at Case: 262-636-7274. He may have more info available...Dennis....
Zach
01-02-2003 16:04:59
 Re: Re: 430 landscaper special in reply to Dennis/Ohio, 01-01-2003 22:47:55
I think i might have an I T manual that i could scan for you if you want it. won't cost me a thing. or i would have to talk to dad but i might be able to sell you the I T manual. if you need anymore help i will dig some info up for you.
Roger
09-20-2003 20:51:21
 Re: Re: Re: 430 landscaper special in reply to Zach, 01-02-2003 16:04:59
Did you scan the manual? If so, I would like to see it.
ThaNKS
Zach
01-01-2003 16:35:39
We have a 430 and the modle # is 440H with a loader modle number 21 and we could get a rebuild kit for it at CaseIH and i don't know how rare it is. ours has shuttle range with duel range but ours has a pto on it.
