CASE 1294 ( 1000 rpm pto possible?)
Al Stearns
03-31-1999 08:36:57
Looking for information on whether we could put in a 1000 rpm pto and still keep the 540. would like to run a Woods pull behind 10 ft. Brush Hog. We looked into changing the gear boxes on the Woods machine but would have to change all 3 gear boxes. Let me know guys! Thanx Al
Elmer
03-31-1999 16:43:46
 Re: CASE 1294 ( 1000 rpm pto possible?) in reply to Al Stearns, 03-31-1999 08:36:57
Try measuring up a pto gearbox from a 990 David Brown. You may have to use the shaft too. It will give you two speeds. I have never done this, but i think it will work.
Al Stearns
04-01-1999 16:52:30
 Re: Re: CASE 1294 ( 1000 rpm pto possible?) in reply to Elmer , 03-31-1999 16:43:46
Thanx Elmer!
So How would you suggest that I find a David Brown pto. gearbox? I'm kind of new to this! Let me know; O.K.
Deere 1
04-02-1999 22:25:42
 Re: Re: Re: CASE 1294 ( 1000 rpm pto possible?) in reply to Al Stearns, 04-01-1999 16:52:30
first try to get a service manual that will tell in detail what and if it can be done We have a 730 ,870 and 1070 and all of them can sswitch to 1000 ,, just remove the snap ring on the tractor pto shaft and remove , reinstall in the oppisite direction ..
