Case SC Hydraulic?
Randy
01-06-2003 13:32:35
My 49 SC was the year before the eagle hitch and has a hydraulic cylinder that stays with the tractor when not in use. The six-foot hoses that attach to the pump with swivels need to be replaced. Should I drain the hydraulic oil before disconnecting the hoses or will I not loose that much oil.
keith
01-06-2003 16:32:25
 Re: Case SC Hydraulic? in reply to Randy, 01-06-2003 13:32:35
I would just drain it. This is a good oportunity to change it. It only holds 10 or 11 quarts so it won't cost that much to replace.
Randy
01-06-2003 18:03:03
 Re: Re: Case SC Hydraulic? in reply to keith, 01-06-2003 16:32:25
Keith you make a good point. I should have thought about that myself.
Thanks
