Case 930 Comfort King Transmision
David
01-06-2003 16:36:02
I have a 1968 Case 930 CK, The person i bought it from says it has an 8 speed trans. I lok at the floor board of the cab all i see at the base of the shifter stick is 1-2-3-4.and N in th middle.
Anyone can shed somelight on this issue. The SN on the tractor is 8336378. Thanks in advance
Mike
10-08-2003 14:42:29
 Re: Case 930 Comfort King Transmision in reply to David, 01-06-2003 16:36:02
Had the set screw unturn on a gear where another gear slides over on the high ,low range where I could only get it to shift from low to neutral.All this being inside the transmission..
Jens Andersen, Denmark
01-07-2003 10:21:16
I have a 1030 which vertually is the sam rear end as the 930 and I have a small lever left of the steeringcolumn actually IN the dashboard, and on
the decal it says H-S-L. Donīt use force when you
move it just ease-it up and down since the shif-
ting-fork has a tendency of breaking.
Hope this helps.
Jens Andersen Denmark
David
01-06-2003 18:54:18
Thank you all..
Rick in N D
01-06-2003 17:15:13
The 930 only had two transmissions. The 6 speed and the 8 speed. The 8 speed is a dual range transmission, that is why you only see 4 gears. There should be another lever for the hi/low range close to the 4 speed lever. If there have been any oil leaks, then the dirt and oil will build up and you won't see the hi/low notation on the transmission top cover.
Don L.
01-06-2003 17:06:44
There is a lever just left of the steering post in the dash. It will give you high and low range.
Don L.
