580 case tractor W/three point hook up
Troy Menix
01-07-2003 07:25:39
I just bought a 580 case Diesel tractor with a loader and three point hook up. The tage said Model 5800k, # 8327181 on the tractor and on the loader it had Model 33, #4150155. Some one told me it had a 188 Cubic inch motor, about 55hp. It runs ok but the steering need some work. As long as you have it reved up it will turn some what easer. If it's idoling it is very hard. Can someone tell me what could be the problem. Also, what year and hp this tractor is. Thanks for the help,
Troy Menix
case poor in pa
01-07-2003 17:26:17
 Re: 580 case tractor W/three point hook up in reply to Troy Menix, 01-07-2003 07:25:39
i just bought a 580 ck to didnt steer.. bought a used pump from DON L email manifold@smig.net witch gave me prresure to the steering cylinders still didnt steer so i rebuilt the cylinders that fixed it check pressue at cylinders should have around 1800 lbs of presure there if you dont youl need to rebuild or replace pump. if ya got good pressure youll have to rebuild or replace cylinders rebuild kits about 20.00 for both cylinders new cylinders are outrageous wow email me if you need cylinders ill send you a addrress where you can buy new ones a lot cheaper than the case dealer that don l has used pumps i think that are reasonable
