This is listed on ebay1947 Case Tractor!!!!! Item # 1876526350 Item located in: Other Vehicles : Miscellaneous Starting bid US $450.00 (reserve not yet met) Time left 4 days, 20 hours + Started Jan-05-03 16:50:01 PST Ends Jan-12-03 16:50:01 PST # of bids 0 ( Bid history ) Location Kingman,Arizona Country/Region United States/Phoenix Its a 1947 Case tractor, it has a 4cyl, the color is orange. It has up and down levers, put a new fuel filter in, has a blade to clear roads, everything works on it. No rust is in good condition, needs a little work on it. Has a brake,gas, and a clutch. It also has a 3 point hook up in the rear and a drive shaft. It is a four speed. It ran the last time I used it the motor may need rebuilt. I purchased it from a older gentlemen that bought the tractor when it first came out. Excellent for clearing fields, or just hauling and moving things. Vehicle Condition New Tires, carburator has been rebuilt, ran last time I used it, but it does need to be rebuilt, over all is a great tractor, has a blade on the rear end, everything is there. Needs some work, has a large gas tank in front, has the exhaust out the side with a stack. All the controls work. t
