Case Sc Compression
Joel
01-08-2003 10:47:59
Hello all! How much variance between cylinders is acceptable when measuring compression? I recently got the tractor going, runs ok. No smoke. Seems to have good power but the govenor isn't working properly and I have that out right now. Are parts readily available? Weights/pins? Pretty wore. 3 Cylinders are pretty close to 110psi but have one thats just under 90. Worth worrying about? Some have told me its weak others say its ok.
Gordon
01-08-2003 17:20:07
 Re: Case Sc Compression in reply to Joel, 01-08-2003 10:47:59
Add up all the compression say you come up with 110,100,90,105,=405 divide by 4=101. Any compression over 20 lb differnce should be looked at.That is 20 lb form 101 79 lb. This is the scale they use on airplane engines.
