Case 1570
Wayne
01-08-2003 11:38:48
Anybody know what causes the oily residue to accumulate around the Intake Manifold?Rear Head is clean,Middle and front Heads are dirty.Sure would like to keep the Engine as clean as the rest of the tractor.
scottAR
01-12-2003 08:05:33
 Re: Case 1570 in reply to Wayne, 01-08-2003 11:38:48
Keep your air cleaner very clean and check all parts of the induction system for restriction ( wasp nests,leaves, etc.). Also look at the turbocharger drain line. I had a 1370 that the rubber hose going into the block collasped on the inside causing a buildup of oil back to the turbo. Then it would push oil thru the turbo and into the intake. It would fill the sky with black smoke until you slowed the motor speed then go back to normal. As you can probably tell, it was not easy to diagnose the problem. Good luck.
