800
Denny
01-08-2003 13:01:34
I've seen a couple of posts here that seem to point to different locations for Case-O-Matic filters on an 800. I've seen one that said the washable filter was on the same side of the tractor as the valves (left side). And I've seen posts about a filter in front of the radiator. My washable filter is on the right side of the tractor and the valves are on the left (same side as the clutch pedal). And there is no filter in front of the radiator. Did they make this transmission with two different configurations?
Also, my washable filter looks like it was cut incorrectly at the factory so there is probably a leak at the filter base. Would this affect operation?
My serial number is 8130303. My serial number book shows 812001 as the first 1958. Since they didn't build 10300 of these in 58, why is mine 813 instead of 812? Maybe I can't read correctly.
Thanks,
