7 inch flat lens Guide Light
what's it off of?
Mike Schotte
01-12-2003 07:50:57
Can anyone help me identify this light?
It's a 7" flat lens Guide Light, and it's painted either a faded red or orange.
The mounting bracket is flat and fan-shaped, and has the number "B1261B" cast into it. The lens has the 1/4" grooves and has "GUIDE TRACTOR LENS 922405" cast into the glass.
There appears to have been an on/off switch located on the underside of the light housing.
A link to some photos of the light is listed below:
Thanks in advance for any help.
Regards, -Schotte
Don L.
01-12-2003 08:53:36
 Re: 7 inch flat lens Guide Light - what's it off of? in reply to Mike Schotte, 01-12-2003 07:50:57
The light is off a Cochshutt/Oliver s "before" 1947. The mount is for a 70. The light itself was used on Case,M.M. and Olivers. A very popular light assmembly used up to the end of WW2.
Don L.
Mike Schotte
01-12-2003 13:27:07
 Re: Re: 7 inch flat lens Guide Light - what's it off of? in reply to Don L., 01-12-2003 08:53:36
Thank you for the info, Don.
Just out of curiousity... how did you know what model this came from? Personal experience, or do you have some original manufacturer info from Guide?
Do you happen to know what Case models used this style light- and if so, what mounting bracket I would need to find for the Case application?
Thanks again, -Schotte
Don L.
01-13-2003 05:09:46
 Re: Re: Re: 7 inch flat lens Guide Light - what's it off of? in reply to Mike Schotte, 01-12-2003 13:27:07
They where used on L, C and R, the D and LA. Sorry, but not on S or SC[ hard to figure]. Your light has a Oliver 70 row crop mount, seen many of those thru out the years.
Don L.
