885/ selectamatic
patrick moore
01-12-2003 16:07:44
when you lower the 3 point control in any of the three settings is not one of the settings suppose to force the blade deeper in to the ground all my unit will do is drag the ground is this right or do i have a problem
James
01-12-2003 17:53:56
 Re: 885/ selectamatic in reply to patrick moore, 01-12-2003 16:07:44
There are almost no tractors made with down pressure on the 3pt. The only one I know of is a tractor that has an aftermarket settup run by an external cylinder instead of the typical internal ram/rockshaft. Add some weight to the blade.
