Case 210B
Mike Johnston
01-13-2003 16:32:39
I am now working on a Case 210B tractor with front lift, and had posted a few questions back in September or so. There were a couple readers that emailed about possibly having replacement parts they'd sell. I no longer have those emails, sorry to say. The first thing that needs replacing are steering parts. This tractor has the non-adjustable wide axle. I need the drag link and drag link arm off a 210B, 300, 310B or 410B utility tractor. I believe they are the same parts. The tractor had the power assist steering, so those parts are needed as well. This thing is a bear to steer without it.
The rear lift does not move at all, so that will be tackled next.
Thanks for any replys or emails regarding possible replacement parts. If you are parting out one of these and have emailed me in the past, I'd sure like to hear from you again.
Mike Johnston
Houston, Texas
John Saeli
01-15-2003 10:20:03
 Re: Case 210B in reply to Mike Johnston, 01-13-2003 16:32:39
Mike; My spotter got back to me. I can supply a new G45372 drag link for $110.00 + freight. I can supply a used arm for $75.00 + freight. How are you coming with that Eagle Hitch? Let me know if I can be of any help.
Mike Johnston
01-15-2003 13:05:40
 Re: Re: Case 210B in reply to John Saeli, 01-15-2003 10:20:03
John,
Sent you an email.
Thanks for the responses and emails.
Mike Johnston
John Saeli
01-15-2003 05:15:49
Mike; I checked this AM, the G45372 is still available. Price is $137.02 + freight in and out if I supply it. The G16667 arm will take more work.
John Saeli
01-14-2003 15:43:57
Mike; The part # for the drag link as you probably know is G45372, and the arm, G16667. The problem is that most dealers won't exhaust all possibilities before telling you they can't get the part. According to the parts book, the drag link does not have replacable ends. What I had to do on the CASE combine when I could no longer get tie rod ends was to take the rod to NAPA, have them match the end for size and taper, buy their replacable end, cut my end off and weld theirs on. Worked very well. They sold Dana - Spicer and they had a catalog with all the different ends offered. The arm looks like a different story. What power steering parts do you need? The Eagle Hitch is a simple system. A pump, valve and cylender. Does the loader use the internal hyd. pump, or does it have an external pump. If the loader uses an external pump, the internal pump for the Eagle hitch could be locked out. The lockout is a small shifting spool on top of the torque tube housing. If I can be of help, let me know. John
Dennis/Ohio
01-14-2003 03:23:50
Hi, I can't tell you what all models you can use parts from but Utility tractors of many models are a possibility for steering parts. Best wishes, Dennis....
case poor in pa
01-13-2003 19:19:41
e mail don at manifold@smig.net hes got lots of stuff for cases new and used
