530CK Loader Removal
Jason Weir
01-16-2003 13:02:59
Can someone give me a quick rundown on the steps to correctly remove the model 32 loader frame from my 68 530CK.
Is there a way to remove it as a unit or do I do it piece by peice..
Thanks
Jason Weir
Dennis/Ohio
01-18-2003 03:20:27
 Re: 530CK Loader Removal in reply to Jason Weir, 01-16-2003 13:02:59
Hi, Since your painting your unit. You could remove the loader bucket. Support the loader, 4-speed area and rear axle area. Thats how I did my 530(non-CK)since I was rebuilding and painting front axle, steering box, radiator etc. (can be done with a floor jack, jackstands & cherry picker). Don't forget the seal between dual range and 4-speed/final drive. Must be a 4 inch difference in these oil levels....Dennis..... .
Captain.n/e,Mo.
01-17-2003 17:36:47
I took mine apart a piece at a time (blown engine)
but after doing it I believe it could be chained up and the tractor backed out. would need a good overhead hoist.
Ron T
01-16-2003 18:26:34
Jason, why are you removing it. Are You going to sell it. If so where are you located?
Jason Weir
01-16-2003 18:58:29
 Re: Re: 530CK Loader Removal in reply to Ron T, 01-16-2003 18:26:34
Sorry, I'm not selling it. I have to split the tractor to replace the syncro in the shuttle so I am going to remove the loader frame and paint the whole thing while I'm at it.
Jason Weir
