900 Case
Randy
01-17-2003 21:35:06
I was wondering what the difference is between a 900 and a 900B Case. Thanks Randy
caseman-d
01-18-2003 14:46:21
 Re: 900 Case in reply to Randy, 01-17-2003 21:35:06
Maybe I'm a little confused on the rotory vs inline injection system. I have seen later and newer 900's with the inline injecture pump. My 1957 900 has rotary, my 59 has is inline. Where I am confused is whats the difference between the single-plunger American Bosch unit to a multiple-plunger Robert Bosch pump. Guess what I think I'm trying to say is it possible to have an single-plunger in line American Bosch pump on a 1958 900.
confused caseman-d
Jim M
01-18-2003 05:05:00
On the diesel they changed the injection pump from a rotary style on the 900 to an inline style on the 900B. I think the LPs were the same.
Ron
01-19-2003 17:02:43
 Re: Re: 900 Case in reply to Jim M, 01-18-2003 05:05:00
I have a 900 B with the in line pump. Does this mean it is a 59 model. I was told that the in line pump is better if you want to pull a 900 tractor. Apparently you can turn to in-line up to where you can get more power out of it and you can't do this with a rotary. Does anyone know if this is correct?
charlie hotalen
01-20-2003 09:09:43
 Re: Re: Re: 900 Case in reply to Ron, 01-19-2003 17:02:43
i have a case 900 and i want to know what kind of hubs for the back cause i have cast hubs and i want to put tin wheels on them so i need to know what kind of hubs i need that will fitt on the case 900 because it has a tapper axle.
Jim M
01-20-2003 02:42:11
The 58 and 59s had the inline pump. If you go to previous posts there is one telling you how to turn up the pump
