CASE VAC DISTRIBUTOR
Jim Robson
04-01-1999 22:56:45
I have a 51 CASE VAC that has been converted to a 12 volt system. I am trying to replace the ignition parts, but I cannot read the ID #'s from the distributor-It appears to be the original . Can anyone tell me about it and suggest what I should use for points, condensor, cap and rotor for this?? (Brand and part no. would really help!!!).
H. L.
04-02-1999 09:35:19
 Re: CASE VAC DISTRIBUTOR in reply to Jim Robson, 04-01-1999 22:56:45
My 50 model has an Autolite Distributor the number on it is IA O(or)D 6003 2F 2G. You will need a dropping resistor or get a 12 Volt Coil. The -(neg) lead from the coil goes to the distributor When I rework my VAC I'm going to install an electronic ignition like I put on My JD3020 LP You can read about them hear at YT
rick
04-03-1999 18:33:53
 Re: Re: CASE VAC DISTRIBUTOR in reply to H. L., 04-02-1999 09:35:19
i have a 48 vac that i converted to 12 volt. i used a mopar 5/50 resistor to drop the voltage to the 12 volt coil a 12 volt battery was installed and a gm alt. the original 12 volt starter will be ok. the dist points and condenser are the same ones that case used on the early ck backhoes with the gas engine
