Case 2390 transmission question
Mario
01-19-2003 20:49:22
I am writing for a friend that has a Case 2390 Tractor with a problem. According to him the tractor is throwing pressuried oil through the breather on top of the transmission. What could be causing this problem. Please help.
Thank You
Mario
John Saeli
01-20-2003 14:08:53
 Re: Case 2390 transmission question in reply to Mario, 01-19-2003 20:49:22
Mario; I saw your question 1'st thing this morning and I thought someone knowing more about it would have had an answer for you by now. The 1st thing I would check would be oil level to be sure it isn't overfull. If he says he didn't add oil, but it is parked outside, it's not impossible for a quantity of water to be in there. I would carefully loosen all the drain plugs on the bottom and check; there are at least 3 I think.
