70 series powershift transmission
howard s.
01-26-2003 10:33:46
Can someone give me an overview of the operational characteristics of the 70 series powershift transmission? Am I correct in assuming it has more in common with the jd quad range than powershift? thanks, howard s.
Pat
01-28-2003 17:07:48
 Re: 70 series powershift transmission in reply to howard s., 01-26-2003 10:33:46
Hi Howard. A case powershift is better copared to a JohnDeere power quad. The Case powershift has four speeds with three powershifts in each "range". On my 970, an older one, I have only three reverse speeds as fourth is blocked out. A worn powershift will usally be VERY jumpy. Start up the tractor and with the range in netural, shift the powershift and watch the pressure gauge on the dashboard. It should flicker quickly into the red zone, and then back to green. The slower the gauge moves the more tired it is. I have my Case dealer check my powershift pressure yearly. It prevents problems and detects leaks in the shift packs. Hope this helps. I have clocked about 3000hrs on my 970 and have no problems. It now has 7200hrs on the tractor and never tore down.
kydavid
01-26-2003 19:16:03
I'm going to do something here I don't like to do and talk about something I don't know much about (quad range??) The 70 series uses the same basic powershift as the other Cases (90 and 96's series). Set of hydraulic clutches let you powershift 1-3 in any of 4 manual gear ranges. Uses a compound planetary gear set for the powershift and a regular unsynchonized transmission in the gear case.
howard s.
01-26-2003 17:17:08
No, I have never operated one, that's why I asked the question. I have owned a jd 4430(quad range) for 14 years, and am interested in buying a 70 series case as a second tractor. It sounds to me as though the case tranny is similar to the quad, which is fine with me, because the jd 20-40 series powershifts aren't anything to brag about. By the way, I have owned two of those(4640, 4840), too. Thanks, HOWARD S.
twopop
01-26-2003 15:29:57
the 70 series trans has a 4 speed range trans with a 3 speed powershift which gives a total of 12 speeds fwd and 4 in reverse the jd quad{ if i remember right}is a 4 speed range with speed main and a 2 speed splitter which gives you 16 fwd and 6 reverse the jd powershift is a true powershift
Don
01-26-2003 18:51:26
 Re: Re: 70 series powershift transmission in reply to twopop, 01-26-2003 15:29:57
The Case powershifts should have only 3 reverse speeds. 4th is blocked out.
Shane
01-26-2003 20:33:17
 Re: Re: Re: 70 series powershift transmission in reply to Don, 01-26-2003 18:51:26
I believe there were some with a reverse in 4th also. I think they were the early ones.
Casedude
01-28-2003 15:13:29
 Re: Re: Re: Re: 70 series powershift transmission in reply to Shane, 01-26-2003 20:33:17
But there really isn't any reason to have a 4th gear reverse. I personally like to drive forwards. ;-) ok i am not tring to start a fight just trying to lighten things up abit.
John Saeli
01-26-2003 15:10:28
Howard; How much do you know about the CASE powershift? Have you ever operated one?
