830 hyd. ?
David
01-28-2003 16:37:54
I recently purchased a 830 case it has the usual 4hyd outlets but only 3 have ends the 4th is plumed back into the pto housing is this factory? or has someone used this for a float position? for a one way cyl.
Bill from up north
01-30-2003 22:15:09
 Re: 830 hyd. ? in reply to David , 01-28-2003 16:37:54
We have an 830 also. We have a similiar setup- except that the hose going back into the housing has a male end on it ,so you can remove it from the outlet when you're not using the loader. We have a genuine Case loader on it, with single acting lift cyls.
Tom in Mo.
01-29-2003 19:20:40
The return line wouldn't be factory but is not uncommon.
An example of a one way hydraulic tool would be the Shaver Post Driver. They are hydraulic power up and free-fall down. On the free-fall down they dump the oil right back into the reservoir.
Jerry
01-29-2003 05:08:18
The one plumbed back into the housing was most likely used on a one way cylinder. My 1952 SC is set up this way.
John Saeli
01-28-2003 17:30:27
David; Yes, all 4 hoses should have the female ends; preferably the old style CASE ends which are still available, part # A28542. Good luck John
