430 clutch
Craig
01-30-2003 01:45:17
I just bought a 430 diesel, the clutch doesn't engage until the pedal is nearly at the top. It doesn't slip but was wondering if I should put a new one in while I have all the metal off. I'm replacing the radiator hoses right now.
John Saeli
01-30-2003 04:47:20
 Re: 430 clutch in reply to Craig , 01-30-2003 01:45:17
Craig; Dennis has a good idea. If the clutch isn't slipping, and you have plenty of threads on the rod; have you tried to adjust the rod to get more freeplay? Good luck John.
Craig
01-30-2003 15:05:42
 Re: Re: 430 clutch in reply to John Saeli, 01-30-2003 04:47:20
I'll give that a try, Thanks
Dennis/Ohio
01-30-2003 02:17:02
Hi, I think you'll be able to tie the clutch pedal down and feel the the distance to the rivets with a wire hook through the timing hole in the bellhousing. If you have my luck, things that work, I shouldn't work on...ha ha, Dennis...
Craig
01-30-2003 15:03:18
 Re: Re: 430 clutch in reply to Dennis/Ohio, 01-30-2003 02:17:02
