1070 Wont Shift into 4th
Adam Whitson
01-31-2003 07:09:27
Going to look at a late 70's 1070. Owner says power shift fine, but 4 speed wont go into 4th. Has been this way for over 2 years. The price is right for this tractor, if the trans holds up. I might even try to fix it myself, if I get some encouragement here. I think this tractor will work well beside my 1030. Is 3rd enough for hay work? Will I miss 4th? I think I will. ANy thoughts?
Shane
01-31-2003 08:33:21
 Re: 1070 Wont Shift into 4th in reply to Adam Whitson, 01-31-2003 07:09:27
We run several 1070's for haying. The only time we use 4th is road travel and in lighter hay to rake. We use a 10 wheel V-rake. Couldn't run in 4th with a bar rake without beating itself to death. 4th gear will give a speed of 10mph, 14mph, and 18mph in the respective powershift gears. Or something real close to that. There is a stopper on 4th gear to keep it from going in when the powershift is in reverse, this could be the problem but that would be too easy!
Indiana corn farmer
05-17-2004 20:29:46
 Re: Re: 1070 Wont Shift into 4th in reply to Shane, 01-31-2003 08:33:21
I don't know anything about fixing it, but I'd doubt you'd need it for haying. $th gear is mostly for the road. My 1070 will 5 or 6 MPH in 3rd, 2nd powershift.
