1948 VAC Belt Pulley/PTO
Jeff
02-06-2003 13:22:23
Is there any way to slow down the PTO and belt pulley on a 1948 Case VAC? I think it is 1,000rpm and I want to make it 540rpm. If anyone knows if this can be done, please e-mail me. Thanks!
Mike from Canada
02-07-2003 11:49:27
 Re: 1948 VAC Belt Pulley/PTO in reply to Jeff, 02-06-2003 13:22:23
you may have to manufacture a new pulley rim using the existing pulley drive hub. there is probably a mathematical equation to find out the diameter.
Unless the shaft speed is 1000 rpm then your up the creek.
good luck!
mj
02-08-2003 07:29:43
 Re: Re: 1948 VAC Belt Pulley/PTO in reply to Mike from Canada, 02-07-2003 11:49:27
For drawbar work all ag models of VA series are to be set at a no load engine speed of 1600 rpm; industrial tractor (VAI) at 1925 no-load rpm. For PTO operations set engine rpm at 1425 engine rpm; this will give 540 rpm at the belt or the rear PTO.
Mike from Canada
02-09-2003 05:13:57
 Re: Re: Re: 1948 VAC Belt Pulley/PTO in reply to mj, 02-08-2003 07:29:43
i dont think case made drawbar pto adaptor for the VAC. is there an aftermarket manufacturer that made one to bolt on to the seal plate or directly to the transaxle?
just curious
mike
