Case 530/630
jason Stiehl
02-06-2003 17:16:19
I have a case 630 farm tractor motor (gas) and am thinking of buying a Case 530 backhoe loader that needs a motor is the 630 motor the same?
scottAR
02-07-2003 18:25:39
 Re: case 530/630 in reply to jason Stiehl, 02-06-2003 17:16:19
I stand corrected if I'm wrong because I'm running on a memory of about 20 years back. The 430, 530, & 630 all had the same CID diesel engine. The gas burners were different CID. The two blocks would bolt up the same at the back but the mounts at the front were about one inch shorter on the gas motor. I remember there being another set of holes to mount the other type of engine. Hope this helps and hope I am right. You will get a quicker response if my post is incorrect.
