1030 pto help
BA
02-07-2003 17:04:19
a 1030 comfort king with 1000pto,can it be converted to 540 ?
Doug
08-06-2003 09:29:05
 Re: 1030 pto help in reply to BA, 02-07-2003 17:04:19
I just bought a 1030 and was told by an antique dealership that the parts from a 930 would work to change it and the cost for parts would be around $400.00. that was confirmed by another man who had done it. For now i just bought an adapter for $100.00 and will run tractor at 1/2 throttle
Tom
02-15-2003 05:54:56
I'm facing the same problem myself, as my 1032 (1030 with wide front end) has a broken 1000 rpm pto shaft. Here's what I've found to date, you'll need 4 parts; 1 gear, Case p/n A32407
1 gear, Case p/n A32420
1 540 rpm pto shaft, Case p/n A64592
1 gasket, Case p/n 1342351C1
Expect all this to cost about $700 new from Case, or you can search for used parts, which is what I'm trying to do. I'm still waiting for a service manual to arrive that I ordered through Case, so I don't know the extent of the work. Although other folks who've replied to my requests for help here have stated it's a fairly major job. Go through the old messages here and search for "1030". Everything related to 1030's over the past few years will come up. Let me know what kind of progress you make! Good luck
Dean
02-07-2003 18:11:39
Yes it can be changed.
