530 loses clutch pressure after warmed up????
Brendan
02-09-2003 12:46:12
Does anyone have any ideas here. Last year I took apart the valve and cleaned it up and i made it run excellent for about 2 months, and now it is doint this, any ideas. Thanks in advance.
Larry
02-09-2003 14:58:54
 Re: 530 loses clutch pressure after warmed up???? in reply to Brendan, 02-09-2003 12:46:12
Check to see if you have good oil flow after it warms up. I had a 400B that would act the same way. Turned out to be a plugged oil cooler,which is located at the bottom of the radiator.
Brendan
02-09-2003 12:46:48
by the way, it is a 530ck with the case=o-matic. thanks.
