1370 PTO questions
Brent
02-09-2003 21:30:37
Our 1370 has the 1000 rpm PTO (I think they all had that). I am thinking of making a converter for it, to reduce it to a 540 rpm PTO. Several questions...
What's the torque rating on the 1000 rpm PTO? I was going to put in a shear pin to protect against overtorque, but need some info re: what to put in there.
Is the direction of the 1000 prm unit the same as the 540 rpm standard?
Lastly, I was going to build something that would be self-contained, filled with gear oil. I was planning on using the timing gears from an engine (maybe a 504) to supply the speed reduction. Any comments?
TIA...
scottAR
02-14-2003 10:30:30
 Re: 1370 PTO questions in reply to Brent, 02-09-2003 21:30:37
Running it slow will work but make sure it has some load on it. I ruined the motor in my 1370 by running at dead idle for about a month on a water pump that was made for 540. Had to do it as the crops were burning and it would pump all the water I could stand at slow idle. It was so choked up by the time I finished the turbo wouldn't turn and the engine couldn't breath deep enough to even speed up over 900 RPM.
DAVE ALVORD
02-11-2003 09:29:17
Brent,
I am with Don. I think you have two options. Depending on the task, run the 1370 a 1000 RPM or so to keep the PTO at half speed and install a 21 spline to 540 conversion. The 1370 has more than enough snap to handle most 540 tasks anyway. The power is staggering so be careful. This is how I mow with a 1370 and a 10 mower. The tractor does not use alot of fuel either becasue it is not wound out. Or, a nice 970 or 870 probably would do what you needed to do and has the stock 540 PTO. Just my two cents...
Don
02-10-2003 19:10:41
The rotation is the same for 1000 and 540. I doubt that timing gears would stand up to that kind of power. Maybe p.t.o. gears from a different tractor. I would look for a older tractor that has 540. 2 tractors is twice as much fun anyways.
