3-point for VAC
Bob Gulbranson
02-10-2003 20:12:46
Ihave a Case VAC serial #545 0513. I need an Eagle 3-point hitch for it. If anyone has got one for sale please e-mail me and let me know how much you need for it and what kind of shape its in. I have the rockshaft and hydraulic pump.
ponch
02-12-2003 04:48:01
 Re: 3-point for VAC in reply to Bob Gulbranson, 02-10-2003 20:12:46
I've got one off a Case 200, probably around 1959. Are you still interested?
Bob Gulbranson
02-19-2003 11:20:50
 Re: Re: 3-point for VAC in reply to ponch, 02-12-2003 04:48:01
I might be if it will fit a VAC. How much do you need for it and what kind of shape is it in?
mj
02-11-2003 03:15:26
Unless you are restoring the tractor for show you'll be better off using draft arms with ball ends like the new tractors. The Eagle hitch doesn't adapt to various and/or oddball implements like the Ferguson system does. The draft arms are easy to make or you can buy ready-made ones from tractor supply stores. Sway chains mounted to the axle housing on the outside of the draft arm brackets allow for easy hookups. Cat.'0' toplinks work well for the lift links if you modify the draft arm end of the links to maintain vertical alignment of the arms. By keeping the toplink, sway chain and draft arm mounts in the same plane the implement will maintain the fore/aft attitude (set by toplink length) throughout the lift range. There are some examples on the link below.
