CASE MAGNETO IMPULSE
L.LAMP
02-11-2003 09:47:32
Does anyone have a breakdown of the impulse coupling to show the parts inside so I can tell why it doesn't lock and trip. Mine appears to have the spring broke and it seams to turn too freely. It does have spark.
Rich H.
02-11-2003 20:05:23
 Re: CASE MAGNETO IMPULSE in reply to L.LAMP, 02-11-2003 09:47:32
If you have a model 41, I have a couple of pages scanned at:
http://members.aol.com/case49dc/index.html
L.LAMP
02-13-2003 19:04:24
 Re: Re: CASE MAGNETO IMPULSE in reply to Rich H., 02-11-2003 20:05:23
RICH HAS A GREAT WEB PAGE HERE. ALL FLAMBEAU GUYS NEED TO TAKE A GOOD LOOK!!!!! !
klyde
02-11-2003 10:14:28
If the spring is broken the impulse coupling wont lock cause the outer shell unlocks the pawl before it can lock. what model mag.
Mike Schotte
02-11-2003 11:07:53
 Re: Re: CASE MAGNETO IMPULSE in reply to klyde, 02-11-2003 10:14:28
Klyde,
I've got two different types of the 4JMA Case mag. One has a plastic coil cover and a wound wire type impulse.
The other has a metal coil cover and a much stronger (not exposed) type of impulse spring.
The one I've got with the wire spring needs the impulse repaired... but I haven't disassembled it yet so see what's broken.
-Schotte
