730 Grove PTO clutch adjustment
Phillip Womble
02-12-2003 18:51:00
My 730 grove model has what appears to be the late type PTO clutch which needs to be tightened. I do not have the special tool mentioned in the owner's manual and the local Case dealer cannot get the tool for me. Anyone have any suggestions?
Gerald Michaels
02-12-2003 20:20:37
 Re: 730 Grove PTO clutch adjustment in reply to Phillip Womble, 02-12-2003 18:51:00
Take a piece of 1/4" x 1" x 12" flat iron and cut a vee notch in the one end, that will fit in the pin to pull it out and then turn clutch untill the other pin engages, then pull second pin out and turn clutch untill first pin engages, keep repeating process untill properly adjusted.
