970 case pto problem
Donnie
02-15-2003 19:08:04
I have a 970 case, the pto will not work when shiftted into gear. are these operated by a clutch pack and a valve? Any ideas where i could start looking for the problem.
Chris
02-16-2003 10:57:11
 Re: 970 case pto problem in reply to Donnie, 02-15-2003 19:08:04
The PTO is operated by a clutch pack. The pump, pumps oil to a flow divider, which contains the valve that your PTO lever cable is hooked to. When engaged oil travels from the flow divider to the clutch in the PTO housing. Is this tractor Power shift or not, and do you notice any other problems such as power steering or 3-point response being slow? I need some more info, because there is some things I would check before getting into the PTO clutch.
donnie
02-17-2003 13:55:44
 Re: Re: 970 case pto problem in reply to Chris, 02-16-2003 10:57:11
chris, the power steering and lift work great. It is a power shift.
bill k.
02-19-2003 08:26:17
 Re: Re: Re: 970 case pto problem in reply to donnie, 02-17-2003 13:55:44
most common problem is broken cable. if not, try hooking hyd. line from remotes to pto housing fitting. that will tell you if the problem is internal.
