1030 PTO
Bill
02-16-2003 18:29:30
I have bought a 1030 with out a pto shaft. I have been told that it will be easy to install the shaft others say I am in for a lot of work. I am told that this tractor had only a 1000 rpm shaft and 540 was not an option. Can someone who knows help..
Tom in NJ
02-19-2003 10:20:47
 Re: 1030 PTO in reply to Bill, 02-16-2003 18:29:30
Bill, I have a 1030 parts manual for the 1000 rpm model. Let me know if you want me to fax you a copy of the pto parts pages. I'm converting my 1030 to 540 rpm - just getting started with turning up the right parts though.
Tom in NJ
02-19-2003 10:20:46
Jeff From WI.
02-17-2003 08:20:41
Bill, I have a 1968 Case 1030 with a 540 PTO. yes they did come with 540 PTO right from the factory.
Jean Claude Marleau
02-16-2003 19:33:59
just want you to know if you need a shaft for 1000 rpm 1030 i have 3 shaft like that.
Dennie
05-16-2003 13:29:16
 Re: Re: 1030 PTO in reply to Jean Claude Marleau , 02-16-2003 19:33:59
I have a 1030 that the shaft from the PTO to the Trans broke on. I think the Pump or PTO is out, causing the shaft to break. Don't know for sure.
Do you have any parts for this. If so, how much, and where are you. I am in Minnesota, but Tractor is in Iowa.
Big Orange
02-16-2003 18:50:04
I don't think it would be a really hard job,does the tractor have pto and the shaft broke or just no pto,540 was available.If it has no pto parts could be an issue,but I'm sure they're around someplace,salvage yards ect.
