580 won't start
Mike
02-17-2003 07:10:03
A friend of mine has a 1970 Case 580 that won't start. He was using it and it started runing rough he found water in the fuel. Fuel was drained and filter was changed now it will not start. There is fuel to the pump but none to the injectors. I loosened the lines to the injectors and ran it on WD 40 sprayed into the intake no fuel, there is fuel in the return line. Bad pump?
Thanks for any help Mike
RoyG
02-17-2003 14:42:06
 Re: 580 won't start in reply to Mike, 02-17-2003 07:10:03
First guess is that the Injection pump hase seized due to the water. Pull the plate off the side of the pump and see if Pump is turning. If not you will have to remove it and have it rebuilt as the Rusa master pump head will lock up with very little water and shear off the drive shaft.
