930 clutch
MGM
02-20-2003 03:11:26
My tractor has been apart for some time and although I have the service manual and the parts manual the placement of some pieces are vague. 1st. Does the Small splined piece smooth end slide into the crankshaft back end and the narrow gear end sit it the flywheel? Does the pilot bearing support the tractors small spline shaft? And is the grease/dust seal on the back of the flywheel goe up on the part between the small spline and large spine in the bell housing?
If anyone has any blown up pics on this I sure could use them! Also, where can I get a cheap clutch alignment tool?
Thanks in advance.
MGM from S.E. MN
