451 diesel
Shane
02-20-2003 16:45:07
I have two 1070's and a 1270 that seem to "chatter" while in use. They seem to do it while above 1200 RPM and more likely in a higher gear. The 1270 is mainly used on a silage blower and will do it almost continously when throttled up. I would appreciate any help so as I can get them fixed before planting season.
Allan Currie
02-22-2003 17:30:18
 Re: 451 diesel in reply to Shane, 02-20-2003 16:45:07
There's an adjustment you can make on the injector pump to stop this. But I don't know exactly what it is. Someone on here should know, I believe it's just a screw on the governow but you have to remove the end cap to get at it. You may have to find an injection guy.
Brian
02-21-2003 08:27:38
Dad used to have a 1070 that did the same thing. It seems like the cab would shake just a little bit on the rubber cab mounts when going down the road and cause the throttle linkage to move. Just an idea.
Shane
02-21-2003 13:25:52
 Re: Re: 451 diesel in reply to Brian, 02-21-2003 08:27:38
That is what someone else said but the 1270 has a cable linkage instead of a rod linkage so the cab movement wouldn't bother it. And the 1270 will do it while stationary on the blower. They all will "chatter" for a bit then stop then do it again. Thought it might be the injection pumps going bad but one was just rebuilt 2 years ago so I don't think that is it. Hopefully it is just out of time, will have to check that Monday. Hopefully someone else has some other ideas. Thanks for your help.
nedd
02-21-2003 06:08:53
I would say piston slap. Have you tried reving the engine up without a load?
Shane
02-21-2003 08:28:39
 Re: Re: 451 diesel in reply to nedd, 02-21-2003 06:08:53
They all tend to do it while going down the road in 4th Gear. Every now and then they will do it in the field.
Thad
02-21-2003 04:02:09
You might want to chack the timing. It could be advanced to much good luck.
Jeff from WI.
02-20-2003 20:13:22
are you talking about that normal ching ching ching that all 451's sound like with there bosch fuel pump? if thats it i love that noise.
Shane
02-21-2003 04:54:07
 Re: Re: 451 diesel in reply to Jeff from WI., 02-20-2003 20:13:22
No this isn't a normal noise, it actually does change the rpm level, however the later models do have a nice sound to them don't they! Especially the turbo models.
big orange
02-20-2003 18:17:41
Is it possible the tappets are a little loose?
