Case 611B hydralic problems
Brad Peters
02-20-2003 18:25:57
Can any one help me!? I replaced a non working case-a-matic and hydralic unit with a known working one. Once I replaced it, it will not work. The transmission is slow moving and does not appear to be any difference in either drive. The eagle hitch is slow when under no load but will not pick up a load. Again, the 611B that I got this out of worked fine, just a bad engine. Any help would be appreciated.
lincoln
02-22-2003 07:24:50
 Re: Case 611B hydralic problems in reply to Brad Peters, 02-20-2003 18:25:57
My 611B hydralics get real slow and week if I don't change both filters every so often. I have always used Case hydralic/transmission fluid and haven't had any problems. Mine does not woork to well in cold weather until it gets warmed up.
