Case 830 eagle hitch accessories
scott
02-23-2003 16:45:28
just purchased a 830 diesel with eagle hitch. i had a rear blade and a roto-vator but not sure how to attach to the eagle hitch arms. they are not like a regular three point hitch. any help would be appreciated. - scott
klyde
02-24-2003 09:59:22
 Re: case 830 eagle hitch accessories in reply to scott, 02-23-2003 16:45:28
My roto-vator I run on my 630 I put 1 pin on pointing out and the other pointing in. Mine also has many different positions for the pins (offset right, offset left, and centered) Where there's a will there's a way.
mj
02-23-2003 18:15:54
On my VAC with Eagle hitch i've been able to get implements with different widths between the draft pins hooked up by loosening the bolts that attach the draft arm brackets to the axle and moving the whole thing on the axle. Not very satisfactory but I haven't taken the time to fab some new arms with ball ends and sway chains. I'm a Case man but Ferguson had the best system and I'm through fighting it!
keith
02-23-2003 17:02:21
Most of the time implements have to be modified to fit the eagle hitch because of the fixed position of the arms. You may have to do some welding.
GeoMo
02-24-2003 05:30:31
 Re: Re: case 830 eagle hitch accessories in reply to keith, 02-23-2003 17:02:21
Hooking up to a standard 3 point should not be a problem if you have the same catagory.
