1030 case missing
AJ
03-01-2003 15:01:49
My 1030 Case, at low speed sounds like it is backfiring. But when you rev her up to about 1200 r's she smooths right out. Could this be bad valves or maybe the injectors?
Jerry
03-01-2003 17:38:17
 Re: 1030 case missing in reply to AJ, 03-01-2003 15:01:49
AJ, Take some time and do this first, run the engine at idle and crack the injection line at the injectorand listen to the sound. I fthe sound does not change then that is the place to start. REMOVE VALVE COVERS AND CHECK CLEARANCES, PULL INJECTOR AND HAVE IT CHECKED, AND BRING THAT CYLINDER UP TO TDC, BOTH VALES CLOSED AND PUT AIR IN CYLINDER AND SEE IF IT COMES OUT THE INTAKE OR EXHAUST.mAKE SURE YOU loosen the radiator cap or take it off in case you have other problems. Sorry about the cap letters
Jerry
mick
03-01-2003 16:29:18
I had an 1170 missing once, best day of my life, never did go look for it!!
Roger
03-01-2003 15:16:41
AJ, is it doing this all the time, or when the engine is cold after first starting it up?. My 930 does something like that when its cold.....Roger
AJ
03-01-2003 15:21:18
 Re: Re: 1030 case missing in reply to Roger, 03-01-2003 15:16:41
It does it worse when it is cold. But it still does it when it's hot too, just not as bad.
Mike Schotte
03-01-2003 15:03:49
You scared me there, AJ. I thought you were reporting your tractor stolen!
-Schotte
