Case 500B Oil Pressure
Frank
03-01-2003 18:28:58
This old Case is running about 7 to 8 PSIG. She sounds fine and it has been running at this pressure since I got her 8 years ago. Should I try to figure out how to increase pressure, figure it's good enough, or start thinking about an engine overhaul?
Thanks
Frank
John Saeli
03-02-2003 17:45:32
 Re: Case 500B Oil Pressure in reply to Frank, 03-01-2003 18:28:58
Another thing I thought about, Sometime down the road parts for that 164 engine may be hard to come by, if they aren't already. John
John Saeli
03-01-2003 19:03:25
Frank; It all depends on what you do with it; How much you want to spend. My "350" with the same engine as you "500" had the same problem. In 1988 I finally fixed it. I pulled the engine and put it on a stand and pulled the crank. Never pulled the head because it ran so good. The crank had to be turned. Don't remember if I did anything to the oil pump. Still carries the correct pressure between 16 & 18 PSI. Hope this helps John.
