Case 580B backhoe swing locked!
Carl
03-05-2003 07:09:33
I went to use my 580B backhoe for the first time since Nov. Started fine, front bucket worked,ran well. Used the backhoe, but the swing pedels were locked up. They moved a little, but not enough to swing the hoe. the bucket and boom worked fine.
Has anyone experienced this? Could it be frozen moisture in fluid causing this one feature to not work? Thanks for the help.
Max
03-05-2003 20:30:12
 Re: Case 580B backhoe swing locked! in reply to Carl, 03-05-2003 07:09:33
I used to have to take the clevis pins out of the linkages and clean out the corrosion from the yokes and the clevis pins. Could this be the problem?
Rich
06-13-2003 18:01:42
 Re: Re: Case 580B backhoe swing locked! in reply to Max, 03-05-2003 20:30:12
There are a couple grease zerts on the panel next to the pedals. There may be a couple of black plastic plugs covering the access holes, remove them and grease, these are easy to overlook.
