Case 400 Power Steering
Twood
03-05-2003 16:49:53
I have a case 400 with manual steering and an adjustable wide front. I was wondering what I would need to do to convert it to power steering. Looks Like I could use the same axle but would have to change the nose that bolts to block and add the pump. Is that right, what do you think that should cost, and what other models used the same parts?
Thanks
Dale in Tx.
03-05-2003 17:23:12
 Re: Case 400 Power Steering in reply to Twood, 03-05-2003 16:49:53
Just the steering sector and add the pump, (have to pull the radiator) Sector is held by six bolts from the bottom looks simple but will come out only one way ,watch fingers! Dale in Tx.
