Case 870 starter
terry
03-06-2003 06:48:40
changing starter and was told there are gaskets and a pipe or hose that should be changed well i am lost on this part so if anyone knows where i could get some info on it please let me know.
David
03-09-2003 08:29:47
 Re: case 870 starter in reply to terry, 03-06-2003 06:48:40
gasket at flywheel mounting rubber boot at solenoid never use silicon near power shift.unless you want to rebuild it.
turbo
03-06-2003 17:52:47
If it is a powershift, there is a gasket to install the starter as the flywheel runs in oil. You can use silicone also if needed.
John Saeli
03-06-2003 16:01:16
Terry; I know of no pipe or gasket. There is a rubber boot where the solenoid sleeves into the top of the starter. Hope this helps, John
