Case 2670 Remotes and Powershift
Richard Marris
03-09-2003 06:02:44
We are having difficulty lifting equipment through the remotes.In powershift 1st., equip. is ok. In 2nd. it just lifts, in third we cannot lift equip. at all. Are there any suggestions please.
turbo
03-09-2003 06:25:24
 Re: Case 2670 Remotes and Powershift in reply to Richard Marris, 03-09-2003 06:02:44
Most likely some or all of the six bolts that hold clutch packs C-2, C-3 together are broken inside the powershift. Sometimes the bearings at the rear of the powershift failed allowing the distrubuter hub to leak. The first is usually the failure, but the two are located beside each other so you will inspect both. Early tractors used 3/8 bolts, later 1/2 bolts.
Shane
03-09-2003 11:35:13
 Re: Re: Case 2670 Remotes and Powershift in reply to turbo, 03-09-2003 06:25:24
If it is the bolts then you can drill and tap the 3/8 holes to 1/2. We did this on our 1270. We also put in an updated clutch pack out of a 94 series tractor. I suggest making the bolts bigger at least.
john m
03-10-2003 19:21:21
 Re: Re: Re: Case 2670 Remotes and Powershift in reply to Shane, 03-09-2003 11:35:13
Hubs can be drilled to 7/16", but not enough room for 1/2" bolts. Make sure C1 C2 piston carrier is splined as earlier ones were not.
Shane
03-11-2003 06:41:35
 Re: Re: Re: Re: Case 2670 Remotes and Powershift in reply to john m, 03-10-2003 19:21:21
Is there only enough room for 7/16? I was thinking it was 1/2. I am not sure now. Thanks for the updated info if you are correct.
