580 Swing Problem
Illini Case
03-09-2003 15:20:21
I just finished adjusting my foot swing linkage to raise my foot swing pedals to a better position than the flat position they were in. They worked just fine until the adjustment. After the adjustment I noticed the swing was sloppy.. then a pop and now I only have a little swing to the right and even a smaller amount to the left. Neither swing is enough to even start to work the hoe and the swing does not stop after you quit preessing the pedals.When I adjusted the swing linkage I still had free pedal in both directions. The cylinders have recently been rebuilt. Any help would be appreciated.
alrman
03-12-2003 04:16:24
 Re: 580 Swing Problem in reply to Illini Case, 03-09-2003 15:20:21
sounds like you have a problem with the neutralizing spring on the swing spool - probably broken the spring or popped the circlip off the spool.
Illini Case
03-09-2003 16:55:28
Another Observation: With tractor not running I can push hoe either direction by hand.
Illini Case
03-09-2003 16:26:47
Another Observation: If I press a foot pedal it cuts out all other backhoe hydraulics.
