1150 crawler
billOH
03-10-2003 09:46:37
I just "inherited" a Case 1150 loader and I'm looking for any information I can get regarding the operation of this beast. To the best of my knowledge it was working fine when it was parked about a year ago. Now it's time to put it back in service and I've never operated one, so I'm all ears...
jeff from wi.
03-10-2003 11:22:37
 Re: 1150 crawler in reply to billOH, 03-10-2003 09:46:37
look on e-bay. look under agriculture, then type in case. good luck!
robert wesley
03-06-2004 16:16:27
 Re: Re: 1150 crawler in reply to jeff from wi., 03-10-2003 11:22:37
What modle 1150 do you have? Older ones have double handle buket operators. Put the shif handles in nutral( all leavers in the center consol in the streight up position. push the thortal down about 1 " and push the lock on the consol down. That should start it. You may have to turn the switch on if it has one. After it starts and warms up a little lift up the throtel till it idles down. The front two handle are track speed the back two are direction. Pedals are left and right brake and engine speed. It can be steered with the handles or brakes. Hope this helps.
Robert Wesley
