1370 jerky
David
03-10-2003 17:37:39
i bought a 1370 about a year ago when you try to take off in 3rd or 4th gear it jumps and shakes like there is no inching clutch the only way to take off with out is dump the clutch power shift works perfect no hesitation or slipping any ideas?thad you still out there?
Shane
03-11-2003 06:35:28
 Re: 1370 jerky in reply to David , 03-10-2003 17:37:39
It might be the torque limiter ring on the fly wheel is wore. What does it do if you put it in 4th and hold the brakes as you let out on the clutch pedal. If it slips then it probably is the ring. It might also just be out of alignment in the linkages and the valve isn't moving in or out all the way. Hope this helps, good luck.
Wayne
03-11-2003 04:15:14
I have that problem with my 1570 when I am starting loaded wagons.I have to get it rolling in 3rd then quickly shift to 4th and dump the clutch.Trying to start in 4th really makes her shake.If yours is doing this without a load I wonder if mine is going to get worse.
john m
03-10-2003 19:15:30
Are the cab mounts worn\loose?
