1070 No Movement
Steven
03-11-2003 03:43:06
If you are driving along, in any gear or powershift selection, and turn the steering wheel completely left or right, where it will not go any more, the foward motion of the tractor stops dead. Engine RPMs do not change. As soon as you let up on the steering wheel it jerks in to foward motion again.
Have changed all fluids and all filters with no change.
Powershift seems to function fine through all gears. Hydrulics seem to to work as well.
Any sugestions would be appreciated.
Thank You
chuccle
08-14-2004 22:36:44
 Re: 1070 No Movement in reply to Steven, 03-11-2003 03:43:06
i just bought a 1975 case 970, it does the same thing, i've only noticed it on hard left turns, too lock, didnt know what it was , thought i bought a lemon at first,but is runs good, gave 3700 for it????? any replies are appriciated
Jim Handke
03-11-2003 14:52:45
Dad's 970 did that. He made the mistake of buying a rebuilt one, and that one didn't work much better. You're better off buying a new one, even though it's quite a bit higher priced.
mEL
03-11-2003 07:22:07
Probably the 8 gallon steering pump is worn out causing the reverse lockout spool to move out of position as it is dependent on steering return oil pressure to function mEl
Steven
03-12-2003 03:01:17
 Re: Re: 1070 No Movement in reply to mEL, 03-11-2003 07:22:07
Thanks for the posts everyone.
Much appreciated.
Thank You
mEL
03-11-2003 07:21:53
